Hello,
I am selling my T-5 out of my 1995 GT that has been built with Astro Performance Gears. I had the gears installed 10,000 miles ago. All the syncros & bearings were replaced at this time also. The gear set that was installed was: http://www.astroperformance.com/product_info.php/manufacturers_id/29/products_id/148
But i had a 94-95 length input shaft installed from Astro. Same power level as this kit but the length is correct for SN-95. The gear ratios in this tranny are as follows:
1st: 2.95
2nd: 1.94
3rd: 1.34
4th: 1.00
5th: 0.62
I had this tranny behind my 306 for 6,000 miles last year then behind my 410W for 4,000 miles this summer. My 410W put down 460lbs rear wheel tq and this tranny handled it like a champ. I am only getting rid of it because I am getting a T-56 Magnum because I will be spraying the car and don't want to push this tranny.
So for sale is:
`T-5 built with Astro Gears with Bellhousing
`Steeda Tri-Ax Shifter
`Stock 1995 GT driveshaft with newer U-joints
`T-5 Cross member out of my 1995 GT
`Spec 3 clutch disc, puck design
(Spec 3 pressure plate can be included for an extra $200)
**This transmission shifts perfect. I've never grinded a single gear in it. Smooth nice shifts on the street and at the track. Also, this transmission has NEVER been powershifted.**
I prefer local pickup, or shipping will be at the buyers expense.
$1200 obo
Discussion Starter #2
bump
PMs replied
bump, still for sale
Sold!
