ok i went to carb...and on the firewall where theres a vacuum tree that the brake booster connects...one ran from the efi intake..well there is no vacuum on a carb intake for that..... how do i get vacuum to my brake booster now??? or will it be ok without???
there should be two vac ports on the carb's tb plate.....use the large one in the rear for pcv and t it off for the booster
just don't use the timed vac port on the metering plate for the booster lol :)
Discussion Starter · #4 ·
sounds good...i guess ill just "T" off that pcv line....thanks guys...
