ok...on an efi car the pcv valve is on the lower intake...well on my carb intake it covers up that hole in the back of the deck that would normally be the pcv...is it ok for me to just get the valve covers with a pcv valve grommet in them???????????
thanks
Derek
Thats what I did when I swapped my 86 to carb.
also what did u use for coolant guage????? i have a mechanical...should i use that?
I did also run mechanical oil pressure and water temp guages. I actually mounted them under the radio. I took out the message center and made a plate out of black plasic. Looks good, just alittle hard to see at a quik glance.
