1 - 1 of 1 Posts
@Boss Hoods
I have called in and emailed in with no responses, So I figured I would try here.
Can you advise on hood struts that will not be too much stress on the frames of your hoods since they are extremely light weight and thin frame rails on the hood?
Redline makes a normal set and then a set for CF hoods, but they said they may not support the weight of your hood. Can you advise on which strut you have used on this hood that you can say you would trust running on your own car?
My other concern is the shape of the rails along the side with the bracket fitting on. I do not want to drill into my hood and order struts to find out my hood may get damaged.
Any advise would be appreciated
1 - 1 of 1 Posts
