Woody, I need to know what oil pan will work on the 1986 G or N 351 SVO block stroked to 408. Canton, Milodon or what ever you use.
I also seen different thoughts on windage trays. Using them or not. Whats your thoughts on scrapers and windage trays. I do like the idea of using the scraper. Would you use windage and scraper with the pan you choose for me? Also this is for rat rod and the frame has not been welded up yet, so changes can be made to crossmember. My concerns are pan ground clearance because it will set low, and stroker clerance. I know all will have small fitment issues.
I had looked at these three. Canton Racing Products 13-672SV Drag Race Oil Pan and the 13-672A Canton model. Milodon 31487 Ford 351-W Pro Comp Full Sump Oil Pan
Thanks for the info,
SMILIES
SMILIES
