1 - 11 of 11 Posts
Banned
I was wondering if anyone has had their stock 87-93 intake ported or any other things done to it and what were the flow numbers and how do the compare to other intakes? I want to build a stock appearing motor but not have it run like stock. :D
Yes! I just "ordered" a stock ported intake from Tom Moss (tmoss). Check out his work here:
http://tmossporting.bravepages.com/
I'm in the middle of my install as I type...
my "standard" port work on a lower has been flow tested at 195cfm average for the 8 runners without using a clay radius on the inlet.
How many hands you got? Who are you, Doc Oc?
Good luck Mark!
It's called a "figure of speech!" :p
Should get it fired up tonight - did you see these lifters I found?
Mark
Super Moderator
OUch...are those out of your car? What causes that?
Yup... It appears to me that they are just fatiged. Several of them have "stress cracks" all over the roller - look at the one on the right towards the bottom - the flash really picked it up - looks like a hair. 275,000 miles and I've floated them pretty bad a few times before my head swap. I think they're just giving up! The (stock) cam looks and feels to be OK...
Super Moderator
Wow...reason I ask is I'm on my 150k stockers with TWS springs and a Comp .533 lift cam and I cannot get the #3 rockers to stay consistently quiet. Sometimes they tick pretty loud and I figure they're getting hammered.
That's exactly what a couple of mine were doing - I could not get them set/adjusted and quiet. And I'm almost positive the worst lifter (left pic) is one I couldn't adjust right... Good luck!
1 - 11 of 11 Posts
