Before put the AOD in I was wondering if anyone knew how badly it will hurt/help my cars performance? Id say it runs low 14's now and I dont really want to do anything to hurt that.
Ill be putting a Transgo shift kit in it, and possibly a 2000rpm B&M lockup stall converter. How does that compare to a stock C4 trans performance wise?
Will that proably bring me to mid 14s?(engine is an 86 ho with E7 heads, converted to carb, 600cfm carter, performer intake, 1in spacer)
anyone else?
No , no , no. I dont know much about c4's so Ill give you my .02 on the AOD. If you have the $ , contact Lentech. If you dont have that much $ , but want a decent trans thats going to put you into the seat and smoke the tires go with these following parts.
www.baumannengineering.com for the shift kit
www.edgeracingconverters.com for the converter
www.b&mracing.com for the trans cooler.
www.converter.com IF you have a little bit more $
With those following parts your AOD will be a night and day difference. I WOULDNT recommend the B&M converters to anyone , but thats me. Good luck.
