1 - 20 of 184 Posts
Hi Mods,
Can we get a 2V Power Adder and 2V NA Sticky thread setup for us 2V guys? It's getting old seeing all the "what hp will I get" questions and we don't have everything in one thread like the 4V forum. I think everyone would appreciate it quite a bit.
So.. How about a Thread titled: Official 2V Naturally Aspirated HP/TQ thread.
and another Thread titled: Official 2V Power Adder HP/TQ thread.
I can template the first submission for the 2VPA and maybe guys can list their mods based off it?
Car: 1999 Mustang GT
Engine: DSS Super Mod Longblock w/Forged internals/Cobra crank
Compression: 9.0:1
Heads: DSS Ported
Cams: Crower Stage II High Lift blower cams
Exhaust: FMS Shorties, Bassani X with cats, factory catback
Power Adder: Kenne Bell 1.7L
Boost/Pulley: 11psi
Fuel: 03 Cobra Tank/Pumps w/ KB BAP
Injector size: Siemens Deka 60lb
Tuned by: Dave Guy SGS Performance
RWHP: 430RWHP/417TQ
Thanks for helping us out!
Matt
great idea, x2
Car: 2000 GT
Engine: 05+ aluminum block, Manley H beam Rods, Manley Pistons, MPH built
Compression: ~9.0:1
Heads: Fox Lake Stage 2 Ported
Cams: MPH Turbo Cams
Exhaust: Magnapack catback
Power Adder: Garrett GT42R
Boost/Pulley: 15psi
Fuel: Ford GT pumps, Fore Hat, -8an line, CPR rails, returnless
Octane: 91 Pump
Tuned by: AZDynochip
RWHP: 556hp/500tq
It's a work in progress, though. More boost and power to be had in a few weeks with some race gas and a new tune.
Car: 2004 Mustang GT
Engine: 4.6 Iron Block, Cobra Crank, Diamond Pistons, Manley Rods
Compression: 9.0:1
Heads: Patriot Stage II
Cams: Comp Cams XE278AH
Intake: Stock PI
Exhaust: BBK Long Tubes, BBK Catted H, Flowmaster 40s
Power Adder: N/A
Fuel: Focus SVT Pump, FRPP Injectors
Injector size: 30#
Tuned by: Dez Racing
RWHP: 308RWHP/311RWTQ
Keep em comin guys!
Hopefully we can get an NA thread and a PA thread from the mods when they spot this. Keep it goin to the top.
Matt
Good idea ....except ....Machs do not have 2v sohc.So how is this going to help anyone here?:rolleyes:
Umm..
You have Sticky threads in the 4V forum for NA/PA HP/TQ.
Matt
Car: 2003 Mustang GT
Engine: stock from oil pan to intake,
Exhaust: UPR offroad X, Flowmaster catback, stock manifolds
Power Adder: Procharger P1SC, 3 core intercooler
Boost/Pulley: 10psi 3.2"
Fuel: Walbro fuel pump, Steeda filter
Injector size: 42lb 01 Lightning
Ignition: TR6 plugs gapped @.032, Accel COP's, Granatelli 0ohm wires
Induction: 75mm BBK t-body, C&L plenum, Lightning 90mm MAF, AFM Power
Pipe, Surge valve vented to atmosphere
Tuned by: Don Walker @ Modular Madness w/ SCT Xcal2, Diablosport MAFia
Power: 413RWHP/423TQ @ only 5300RPM... not bad for havin a slippin belt, bad clutch, and DIRTY air filter
Engine: 4.6 teskid aluminum block, Cobra Crank, Manley 18cc pistons (30 over), Manley I-beams
Compression: 9.75:1
Heads: Stock
Cams: Comp Cams XE270AH
Intake: Stock PI, C&L Plenum with 70mm BBK TB
Exhaust: MAC Long Tubes, MAC Prochamber, Flowmaster 40s dumped
Power Adder: N/A
Fuel: Focus SVT Pump, Accel Injectors
Injector size: 24#
Tuned by: DynoTuneMP (Mike Post)
RWHP: 298RWHP/313RWTQ
Hit with a 125 zex wet shot and made 396/455 (bottle long gone off car)
2000 mustang gt, 5 speed
prof. products 75mm tb
trick flow plenum
mac h pipe, mac cat back
procharger p1sc 7.3 lbs of boost
369 hp, 406 ft lbs.
Car: 2003 Mustang GT - Torch Red
Stock block and heads
Intake: C&L Upper Plenum
Throttle Body: Accufab 75mm TB
Inlet: Anderson Power Pipe
Headers: BBK Ceramic LT's w/H-Pipe
Programmer: SCT XCAL2
Electronics: Diablo Mafia
MAF: Ford Lightning 90mm MAF
Injectors: 42lb
Fuel: Ford GT Pump (running out of fuel at 6000rpm. will need to upgrade)
Gear: FRPP 4.10's
Drive Shaft: FRPP Aluminum Drive Shaft
Flywheel: Fidanza Aluminum Flywheel
Clutch: CenterForce Dual Friction CLutch
Cams: CompCams xe274 Cams/springs/retainers
Tuner: CRT Performance - Norwalk Oh
PA: ATI P1SC w/3-core IC, 10# pulley- 426rwhp/417rwtq
11.93 @ 122mph (traction limited)
Btw, this has dyno'd at 440rwhp and 431rwtq on my drag tune which I haven't tried at the track yet.
See my run below before the cam upgrade and running 371rwhp. This is when I ran the 11.93. (forgive the video the wife was taking it). Since then I have been to the track after the cam upgrade and was trapping almost 122mph in the traps but could get off the line. Over the winter I have added MM UCA & LCA as well as full length subframes and am going to switch to MT Street Drags. I was running Nitto drag radials. (we'll see how long the rearend lasts...)
http://www.youtube.com/watch?v=GrSgEM2HSys
Car: 2002 Mustang GT
Engine: stock 4.6 with steeda pulley's
Compression: stock
Heads: Stock
Cams: stock
Intake: Stock PI with ported stock plenum and tb and 1/2" spacer with replacement k&n
Exhaust: MAC Long Tubes,vrs off-road x-pipe,stock catback
Power Adder: N/A
Fuel: stock
Transmission: stock 4r70w with pi 3200 tc
Injector size: 19#
Gears: 3.73
Tuned by: Brooks Speed (Eric Brooks)
RWHP: 253RWHP/291RWTQ
2003 GT 4.6
245 rwhp / 289 rwtq.
Dyno Tuned by Dez Racing (Seekonk, MA.)
BBK 70mm Throttle Body
Mac H pipe
Borla exhaust
Steeda Tri-ax shifter
Cobra calipers
3.73 gears
K+N drop in filter
315/35/17 on Rear, and 275/40/17 on Front.
Eibach 1.5" springs.
Engine: stock
Intake: BBK CAI, Trickflow 75mm TB/Plenum
Exhaust: BBK LT's, VRS o/r X, Mac Flowpath CB
Power Adder: n/a
Tuned by: Monty Johnson; JMS Chip and Performance
RWHP: 271rwhp/313rwtq (before the TB/plenum)
Discussion Starter #18
To the top...
Still no moderator input... well.. at least we're collecting data. Keep em coming.
Matt
2003 GT
Stock shortblock
Ported heads
comp 270's
30# injectors
Edelbrock intake
EFI Spyder elbow
75mm TB
FRPP Shorties, BBK X-pipe, Flowmasters
Electric WP
UD Pullies
Tuned @ Supertune Performance w/Xcal3
Stock 3650 and clutch-Changing soon thanks to ProMotion
303/288
12.73 @115 1.73 60'
Witn NX 4150 plate and 80 shot
382/427
[email protected] 1.58 60'
Kansas City International Raceway
3.73 gears and 27" MT ET streets
Needs more gear
1 - 20 of 184 Posts
