I know that the Steeda Sport springs lower the car 1-1.2 in and
that the Eibach Sportlines lower the car 1.75-2.0 in. I want a ride that handles well on the street, isn't a bumpy ride, doesn't look like a 4x4, but will also perform decently on the track and give good launches. What should I go with?
I have some fox body tokio illumina adjustable shocks and struts and MM CC plates. Based on my performance needs, which set of springs should I go with and will I need the x2 ball joints, adj upper rear cont arms, and bumpsteer kit, or are those 3 things only needed with a 2 in or more drop?
Steeda springs with Bilstein struts and steeda C/C plates. My set-up is nice. I could not imagine going down another 1/2 inch on my ride, because my tires would probably rub the inside of the fender or the tire would push out my fender.
edit: my tires are 285/35/18 I also have offset steering rack bushings and I have G-Trac 1,2,3 on my car.
