1 - 1 of 1 Posts
For sale one set of used but in good condition Steeda Caster Camber plates for a Mustang or Cobra, may fit other cars as well $120
1994 - 2004 Mustang Steeda Caster Camber Plates Kit Steeda 555 8094
Steeda's Caster Camber plates allow total adjustment of caster and camber for maximum handling. Durable nickel plated construction and serviceable strut mount bearings provide precise alignments and extra long life. Perfectly balance caster for straight tracking and camber dwell for tight cornering. Steeda's team will provide you with all the necessary specs for your application (street or track) with your purchase.
Strength and Durability Benefits:
  • Lifetime warranty on caster camber plates
  • Allows for independant setting of left & right
  • Direct bolt-in - No modifications required
  • 1/2 the weight of other plates
  • Complete adjustment of caster and camber for better alignment
  • Universal plates - perfect for street & race!
  • Finally, correct camber to eliminate excessive tire wear
  • Dial in more negative camber for better cornering
  • Reduce camber for less rolling resistance on drag cars
  • Add up to 2 more positive caster
  • Straighter tracking and better high speed stability
  • Better steering response, quicker turn in
  • Precision spherical bearing with stainless steel race
  • Holds precise alignment in ALL driving conditions
  • Teflon lined bearing never needs lubrication
  • Bearing is replaceable
  • Less friction than stock bushings
  • Offset bushings allow custom adjustment of strut height
  • Increase suspension travel on lowered vehicles
  • Increase strut extension travel for more traction on drag race cars
  • No interference with hoods or strut tower braces - common problem with other brands
  • TIG welded and nickel plated for strength and durability
1 - 1 of 1 Posts
