Here lately my car has had a problem starting on the first try. The other night i went to get gas and when i went to start it back up after refueling it would not start.... turned over like a sob but wouldn't run. Came back the next day and it started right up. Then sometimes when i go to start it i can here the starter run but it's like its not spinning the flywheel, just sounds like the starter is running freely. On the next attempt to start... it starts right up. Could the flywheel or starter be missing a tooth?? Also it just has not been running all that well(very rich). now there is a weird whine while driving.... hope my tranny is not going. any ideas on anything please!
as far as the starter if you dont hear any grinding then more than likley you are not missing teeth.jusy replace the starter.
