Every since the swap to c4 from t5 the starter is making this nasty screeching sound. Even before it fires up, when it is turning the motor over it just doesn't sound right. Could the starter be different from standard to automatic? I've always thought that they were the same. Any help would be appreciated.
Discussion Starter #2
i dont know about having diferent starters for auto/manual but you could just have it mis-aligned. thats what can happen if the starter is just off a little bit. it will eventually start hacking away at the gears if it is bad enough...
take care,
adam
