When I turn the key I just hear the starter motor spinning. Other times the starter will engage with the flywheel but disengage before the engine fires. Other times the starter works perfectly. What's up with this little bugger?
problem
You need to replace the starter or the solinoid on the fender wall
second: did you guys replace you big starters with the mini starter
Just a thought:D:cool:
i had already just replaced the starter and still had the problem, took the brand new starter back to autozone and now its working, thx
