Jersey True Street Guy
Hello Everyone...
Help the pushrod guy out here....
After my car has been sitting for over 24 hours or so in the cold (lets say under freezing), when I start it, it will start, but it won't idle, it will simply die unless you are on the gas. It smells a little strange out of the exhaust when this happens too.
Does anybody have any advice on what to check out.
Quick mod summary:
Steeda Timing Adjuster
K&N drop in filter
MAC off road
MIL eliminators
Borla Cat Back
Thanks!
It's most likely the IAC.
If it will idle after warming up, then a good cleaning of the IAC should do. If not, then you can try cleaning it and see if it helps; otherwise, just replace it. Either way, it's an easy task, just the IAC's are overpriced, if you ask me.
