My car had Southsides on it when I got it. I'm taking them off and the adjustable Granatellis seem backwards with the bushings. Yes I know which way they go. On the SSM bar the front bushings are wide and the rears are narrow. The Granatellis are the opposite. The SSM plates have been welded on the inside of the rear mounting points. Is this correct? I can put some washers in the front of the new bars, but the rear bushings are too wide. Do I need to cut the SSM plates out?
I figured all fox body stuff was the same width. This really through me for a loop. Anyone have any input or similar experience?
Yes, start hacking. The weight jackers kick a$$, but they take a while to get adjusted just right. Where did you get them and what did you pay?
