hey i was driving home last night (97 cobra) and while pulling out of the parking lot my clutch had a VERY light vibration while engaging and disengaging the pedal...Then, as I came to a stop, a light squeeling like my belt slipping started...Light turns green and the squeeling stops...I pull into my place the squeeling now is happening while driving very slow through my neighbor hood, I rev the motor up, the squeeling stops...The clutch also seemed to get more and more mushy as I got home...The squeeling is VERY loud while ideling and not in gear...I push the cltch in and the squeeling somewhat goes away...The clutch grabs fine, no slipping, etc. And I was driving normally, no racing or anything. What could it be? Would a bad belt cause my clutch to act funky? Low on fluid? If so where is the reservoir to check? Bad clutch? etc? Any help is appreciated...
Discussion Starter #2
ok, i just went and started it...its definetly not anything to do with the belt...the clutch was VERY hard to push in at first, started it up, and a LOUD whine came from somehwere and continued...I pushed the clutch in and it quited a little bit, but not much...it got a little easier to engage and disengage, but it was still quite a bit harder than usual...all the gears go into place, just makes a loud shrieking noise and the clutch is tight...any help???
eh...so the noise goes away when you push the clutch in? maybe your throwout bearing...
it doesn't fully go away...it gets quite'er, but doesn't go away...plus the clutch is hard to push in...
Its the TO bearing... for sure , usually they almost completely go away with the pedal in however. Idle they are noisy!
i have this go bad on every damn mustang i own .. sure is annoying!
yeah it was the throwout bearing...it was loud no matter the clutch was in or out, got some balls and drove it to a friends house to fix it and the sound went away all except idle...
