I am toying with the idea of selling my engine and going a different route. It is a fully built 327 cubic inch stroker. Same as a 331 but with a standard bore. The engine has very little time on it. A handful of dyno passes, 3 track passes and about 500 street miles. Here are some specs on the engine.
Ford Racing B50 Sportsman Block Standard Bore P/N M-6010-B50
Probe Heat Treated 4340 Internal Balance Crank P/N 14906C
Probe 1000hp Forged I-beam Rods with ARP 2000 Cap Screws P/N 1202-10066
Probe Sportsman Pro Series Race Pistons 2618-t61 Material P/N 14111-STD
Total Seal Conventional Race Rings Filed to .028 Top and Second P/N CRL3690 5
TCI Flexplate
Romac Harmonic Balancer
(Rotating assembly Is fully balanced. Balancing was done by STK in Coweta,OK)
Moroso Main Girdle w/ARP Main Bolts P/N 22928
Melling Oil Pump P/N 10687
Moroso Oil Pump Pick Up P/N 24516
Moroso Oil Pan P/N 20511
Lunati Hydraulic Roller .560/.576 242/252 @ .050 110 Lobe Sep P/N 51018LUN
Comp Cams Short Travel Race Lifters P/N 877-16
Comp Cams Timing Set P/N 3138
Arp Head Studs P/N 154-4001
Cometic Head Gaskets P/N c5511
Trick Flow Twisted Wedge R Cylinder Heads
FelPro Intake Gaskets P/N 1262r
Trick Flow Push Rods
Trick Flow Roller Rockers
Msd Pro Billet Distributor P/N 8598
Taylor Spark Plug Wires
Moroso Billet Electric Water Pump P/N 63585
GM One Wire Alternator
March Alt. and P/S Brackets and Pulleys
Edelbrock Victor Jr. Plumbed with N.O.S. Pro Fogger kit and Purge
Holley 750hp Carb
Accufab 2" Primary 3.5" Collector Headers
I am sure i am leaving something out, but that is the bulk of it. In a full weight Foxbody (3400lbs w/driver) c4 trans, 3.55 gear, 28" tall tire it went 10.67 @ 131mph on a small progressive shot and a very soft tune. With a good gear and proper timing it should run a bottom 11 on motor and 9.9X's on a 250hp shot. With a different converter it could possibly go faster. Engine has great oil pressure 80+ psi when cold and 45+ when warm. Runs 180-185 at full temp. Engine is still in the car so you can hear it run and go for a ride with cash in hand. I am looking at $5500 or best offer. Open to trades as well. If you are interested or have questions, feel free to pm me or text 918-378-5083. Thanks
I am also willing to ship at a cost depending on the selling price.
Discussion Starter #2
More Pictures
To the top.
Bump for price drop. $4800
