Hi I am looking into gears and a limited slip for my 95 gt. My question is what size is the rear end and how many spline axles do I have. I'm almost positive it is 8.8 with 28 splines, but I wanted to make sure before ordering them. Thanks
yes, stock axles are 28 spline. Make sure you get axles for a 94/94 since they are a bit longer than the older 4 lug axles. Also let the vendor know if your car has ABS or not. If so, you need to transfer the ABS rings to the new axles.
B is correct and make sure they do not give you a 99 & up axles, they are longer.
Your 95 GT already has a traction lock from the factory. The clutches are probly gone in the rear end. Can do the new clutches when the gear change.
