Question
I have 3.73s in my 94 Cobra. The speedo is off by 20% (mile marker=1 mile, odometer=1.2, after 5 miles, odometer reads 6). I have the 20 tooth and the local tranny fella said I needed a 22 tooth. Does this sound correct? If not, do any of y'all know which tooth and where to get it ASAP? I need to have correct reading for when we go to HotRod Power Tour next Friday in Kansas City. MO.
Thanx for any advice yous can give me.
Albert
:confused:
You need the white 23 tooth gear. This will put you less than 5%. The white 23 tooth gear is not a Ford part, but can buy it at Steeda or Houston Performance. Have heard it can be had at the Jeep\Dodge\Chrysler dealer as it is a Mopar part. Don't know the part #. Can pick one up for around $15.
Discussion Starter · #4 ·
Hmmm, interesting scenario. Here Im told it is the 23 tooth gear and at stangnet, a fella mentioned the 21 tooth Ford gear. Help!!!! I need to order/purchase one today. Which one is it? hmmmmm.
:D
Albert
23. Word of advice, the people here for the most part know what they are talking about. Stick with one website.
You need the 23 tooth. its gonna be the most accurate. thats what i had to get for my 3.73. I think if you go to texasmustangs.com and look it up itll tell you exactly which one you need. good luck
