1 - 8 of 8 Posts
you sure about that? 3.55s usually take the 20T (tan I think) right now with 3.73s I believe I have a 21T.
This is an AOD, I believe with 7 tooth shaft.. but then again some AODs had 8 tooth shafts....
I think most AODs in Mustangs had 8 tooth drive gears. My T-5z has a 7 tooth drive gear and I have a red 21 tooth speedo gear and 3.73 rear gears. With my old 8 tooth AOD, I had a 23 tooth speedo gear which was a white aftermarket gear with super thin teeth that always break off. Ford doesn't make a 23 tooth gear, or at least didn't. I don't know if they do now.
If you have a Ford Motorsport catalog, the speedo gear info is in the back somewhere. I don't know where my catalog is right now.
you wnat a 23 tooth gear, ford makes the part it is DOOZ-17271-B
i paid $7.48 for it.
i had a 90 aod with 3.55 gears and 16 inch ponys w/245-50's all around
remember tire size has alot to do with it too
hope this helps
well regardless of what people say that gear is, it worked on my aod with 3.55's it read 2 mph high at like 95 mph and was dead on at 45-50 mph, i got the formula from mustnag 5.0 magazine about a year and a half ago it calculated rear tire size and ring and pinion gears to give you the correct part number
sorry about any problems caused
:eek:
1 - 8 of 8 Posts
