1 - 1 of 1 Posts
I just put in a spec stage 1 clutch in my 95 gt and am having some problems. The clutch has 2500 miles on it, i broke it in and installed it properly(I have installed many Clutches) . I did not have any problems until the other day when a winning noise came from the clutch. It mostly happens when i push the clutch pedal in. It is not a throwout bearing and i tried adjusting it with my UPR quadrent. Nothing has helped. It sounds like there is a high spot on the clutch when it rotates. The clutch does not slip or burn at all. Any imput would be greatly appreciated. I really do not want to pull it out and put another clutch in.
1 - 1 of 1 Posts
