its late at night and im thinking crazy, but wouldnt this add hp... take a smog pump line and run into your egr line and it would put air into yoru intake manifold tell me if this is possible and if its ever been done... or anything, thanks
Do a search for "Air Pump Supercharger" or something like that. The air pump does not put out the kind of volume you need. The idea is up there with the "Leaf Blower Turbo".
screw that itll never work..but try this power secret...run one of your a/c ducts into your CAI.
Even if the smog pump pumped enough air, in the location you described, it would be behind the MAF and would be unmetered air... if the computer doesn't know to supply the extra fuel, then there wouldn't be a power increase, rather a bad lean condition.
I'm not sure if Fauxbra was joking or not, but running a duct off of AC and running the AC would not be a performance enhancement. Turning the AC system on sucks more HP than a little bit of cool air would ever make up for.
Exactly.
