well just purchased a set of 42lb injectors 80mm mass air, explorer upper and lower and a f303 cam..everything else is stock except exhaust and v3si trim 10psi.. what kinda numbers should i expect also do you think this is a decent combo..stock heads
im not the perfect one to talk about blown applications but stock heads? you paid a good amount for the blower im sure and the rest of the goodies might as well throw in a set of at least gt-40 or something better then lovely e7 heads.
im not familiar with the specs of the F cam, but if its anywhere near .490 lift i think stock valvetrain is junk for that. (my cam has 530 lift and old valves woudl start to flaot arudn 4500)
