so would I forgo the addition of freon by weight and rely entirely on pressure alone? I saw someone mention that above but wasn't sure
At this point, you really can't. If you had the machine, you would recover the refrigerant, pull a vac and recharge again. Since you don't really have that, you need to switch to using pressures.
I don't think you need to add much more, but do agree with Dwain that you need a little bit more. However it's possible that's because you didn't have the proper level of oil in the system.
WOuld need to see high side pressures here to really tell you next steps. Remember, you want to take your readings over 1500 RPM with fan to max and the doors open (to avoid any recirculating air). The goal is to cool purely 90 degree (or whatever outside temp is) across the evap and no recirculated air.
I don't have an SN95 service manual in front of me but I beleive low pressure cutoff is around 20psi. When you hook up the manifold guages with high/low pressure guages, pay attention to the low side when it drops and note where the pressure cuts off. When it cuts out, note the high side pressure. If it's very high 300+PSI or more, that would suggest either a blocked orifice, or poor airflow across the condensor. If you spray water and it drops, you need more airflow.
If the low side cuts off at 20psi or so and your high side is sub 200psi on a hot day, you just need more refrigerant. In fact, on a hot humid day, that compressor shouldn't really cycle much at all. Should hold pretty well around 40-45psi and your high side should be 250-275ish.
You should be able to maintain 40-45 degrees vent temp at idle with doors open.
But I also do think you have an airflow issue through that condenser.
Good luck, as i will be away from internet for a few days
