1 - 1 of 1 Posts
For sale on set of Maximum Motorsports Forward Offset Front Lower Control Arms for a 1994-2004 Mustang or Cobra, may fit other cars as well. $325 These control arms have been installed but not driven on, like new condition.
MM Front Control Arms, 1994-2004 Mustang
Reduces unsprung weight. Reduces overall weight by nearly 40 lbs. with the combination of MM Control arms, MM K-member, and MM Coil-over Conversion Kit.; Improves steering response and controls dynamic alignment better. Increases tire clearance, allowing a smaller turning radius.
www.maximummotorsports.com
Maximum Motorsports has used a unique and true A-arm design that maximizes rigidity and equally absorbs all impact into the K-member. The arms are gusseted in strategic locations to ensure the control arm will bend in an accident, absorbing energy, before a weld will ever break. The smaller bushing design helps create a quicker steering response. All Maximum Motorsports control arms feature low friction ball joints greater ride quality and handling. These arms will move the wheelbase 1 1/2" forward with MM K-member and 3/4" forward with the factory K-member.
Fits 1994-04 Mustang
MPN# MMFCA-10
1 - 1 of 1 Posts
