The stock length upper is the larger restriction once the lower is ported. What I'd like to see is a test of a reverse taper 1262 size ported lower vs a 1250 port ported lower just to get an idea of the true impact. Never seen that test before and we've never done it either.That's what I worry about with a ported lower, how does it flow versus the upper. I'd like an intake ported for my 347, not an Explorer(I have one from you already), but hopefully with thoughtful care about tapering the ports sizes from the inlet and down, somewhat evenly.
I have an untouched Explorer upper plus that lower, and a used raw Edelbrock RPM II, and the one I want ported to use.
The guy definitely didn’t pay $250, and the upper has been cut and welded back together on the side.#786 is NOT our Stage 3 it's our entry level Stage 2 done in late 2019 fyi. It DID NOT receive our cut, shortened and welded upper. We have a detailed order tracking system to be able to verify everything we port. We even have the name of the original customer (Ricky). At the time the order was placed the original customer paid $250.00 for our stage 2 on that Cobra gt40 manifold. So this is a comparison of our entry level stage 2 which flows very well and designed for street/strip applications from 1,500-6,300rpm plus.
This is my intake and has been cut I'm 100% sure. Think you just miss read numbers.#786 is NOT our Stage 3 it's our entry level Stage 2 done in late 2019 fyi. It DID NOT receive our cut, shortened and welded upper. We have a detailed order tracking system to be able to verify everything we port. We even have the name of the original customer (Ricky). At the time the order was placed the original customer paid $250.00 for our stage 2 on that Cobra gt40 manifold. So this is a comparison of our entry level stage 2 which flows very well and designed for street/strip applications from 1,500-6,300rpm plus.
Oh ok. Looked like 786. I will edit my comment.This is my intake and has been cut I'm 100% sure. Think you just miss read numbers.
Thornton said this is his stage 3.I'm late here, so let me get this right, the OP is comparing a Box r with a 90 mm tb tunnel to a long runner stage 2 Cobra with a 80 mm tb tunnel?
Oh my mistake, I must keep my glasses on! Lol. Then this should be interesting. I apologize to the OP.Thornton said this is his stage 3.
2.3155 in² < 2.583 in²Sounds like no reverse taper and shortened runner length. That should make it more interesting.
I wanted to spice it up a little bit.just curious why measured in mm... canada? or some other county thats non SAE?
wouldnt it be more useful to do measurements in inches in a case like this in 'Merica?
Doh. I guess I should have paid attention to the measurements. I really didn’t pay them any mind since they were in Canadian and upside down. Plus, I don’t do the long runner EFI intakes.2.3155 in² < 2.583 in²
Math does not lie....
But he uses science according to his videos.Bernoulli's principle be damned!
What did the spacer look like that went on it?
