I swapped to the SN95's on my 84 which previously had 90 5-lugs. I am putting on the cobra R's 17x9 with 5.95 offset.
The problem is that just dry fitting the wheel I found that my brake lines WILL be hitting the tires as well as the wheel hits the A-arms on the backside.
Has anyone else had this problem and came up with a simple fix? If so let me know.
Thanks,
Nat
Super Moderator
You should be able to tie the brake lines out of the way, at least if they're braided stainless (a good idea). As for the wheel contacting the control arm, install some more rack travel limiters on the steering rack, part number is available on a search, and they're cheap and easy to install.
