I'm still working this axle issue. Can anybody tell me if the ABS ring comes off or is it machined as part of the axle. I'd really like to get a pic of an axle out of the housing if anybody has one or a view from a manual.
The ABS rings are pressed on with an interference fit. Yes, they can be removed and reinstalled on another set of axles. It will take a large hydraulic press and some blocks to constrain the rings while pressing. I recently swapped in some Mosers and put the stock ABS rings on the new axles........no problem!! Sorry, no pics.
Hope this helps,
Wayne
SNAKEBIT95 said:
Yes, they can be removed and reinstalled on another set of axles. B]
Yes and no. You should NOT reuse ABS rings. They can slip. They are cheap (~$20 each???) and you can *order* them for Ford. They will take about a week to get. See my ABS page for the proper offset.
