1 - 8 of 8 Posts
I want to eliminate my smog pump, but was told it is not necessary to purchase the smog pump eliminator, but can be accomplished by installing a short belt instead. Does anyone know the belt size I need? Do I have to remove the smog pump also?(it looks like I do not need to, just add the shorter belt)
Thank you for any help:joy:
anytime I change an accesory(SP?) and need a different length belt, I just take a string and and route it around all my pullies. Having an adjustabl belt tensioner makes it alittle easier so take into account your tensioner being at full tension.
That site doesnt tell you if you can run that short belt with UD pullies... can you?
Depends on the size of the alternator pulley.
Discussion Starter · #7 ·
It shouldn't make a difference with underdrives, as long as you have all three pulleys installed (Alt, WP, crank). With all three on it is the same length belt as stock. I am going to try the info from that web page (I noticed the path is different). Thanks!:cool:
1 - 8 of 8 Posts
