I have noticed my rear tires, radial and my Mickey's are wearing on the inside edge, about a 1-2 in strip. Someone told me this was possibly a bent axle tube. It was another driver at the track.
Has anyone else ever had this problem? What all could cause it?
Also if axle tubes are bent, is there a fix or is it time for a new rear end (drum to drum)?
Thanks,
Rod
Regarding the slick wear, try rotating your slicks after every run. It does work!
I do rotate, but they both wear on the inside..both sides of car wear this way. I have the same problem with street tires wearing on the inside of both sides on the back of the car.
Thanks,
Rod
