Has anyone used this gauge?
http://www.nordskogperformance.net/d80070.html
It looks pretty slick. Has high and low memory, adjustable warning/switched output so it could be used like a nitrous fuel pressure cutoff switch. I have had a couple of buddy's use the Automemter and they went bad. This one is a little (very little) cheaper and had more features.
Robert
My question is why the Autometer gauge cost so much in the first place? The oil pressure (electric version) isn't that expensive, and you CAN use one as a fuel pressure gauge, but for some reason, they try to get fancy with a 0-100 fuel pressure gauge and charge an extra $100 for it. Makes no sense to me. I know of a guy that works for Ford that is an engineer and he used to use a VDO oil pressure gauge (electrical) as a fuel pressure gauge in his test cars because he couldn't stand autometer. I thought it was an interesting choice.
Also, if you notice on the nordskogperformance website, they sell a fuel pressure 0-100 lbs sending unit. I bet you can use it with any 0-100 gauge if you can find one by itself...
