Just some start-up questions.
The turbo is a T-64. Is there a procedure to pre-lube the bearing? I could pull the distributor and spin the oil pump get it primed, but is it necessary?
Also, shut down procedure. I know the turbos need time at idle before turning off the engine. Is 30 seconds enough, or should it run a full minute.
Thanks again for the info!
All you should have to do is hook it up and go. As far as the shut down time, the only thing you have to worry about is not shutting off the car if you have just ran it hard. This will "coke" the oil on the bearings. That is the reason for letting the car run for a minute or so after running it hard. In other words, just don't flog it and then shut it down immediately and you will be fine.
Moderator
If you are truely worried you could siphen(sp?) some oil into the turbo itself before fire up. I have watched people do that via a hose and funnel, never bothered to do it on any of our cars though, but we are just lazy like that.
Well, if a certified and licensed "Turbo Wizard" doesn't, I'm not.
Thanks for the help.
I gotta say, the turbo looks sweet as hell sitting up on top of that exhaust header. I can't wait to get the car cranked up!
Moderator
haha ... Well we were just being lazy by never doing it, our justification was they is "lube" used in the assembly process as is and the oil from the motor gets to it in a very short amount of time in the start up process. Good luck with it and if you need instructions for that kit, I think one of my friends has a set, shoot me a PM if interested and I will try to contact him and see what he can dig up.
