How can I clean the throttle linkage up? It's pretty black, oily and dirty. What do I use to lube it? I only ask cause it got stuck at WOT yesturday, in traffic (an unwanted powerbrake burnout).
Discussion Starter #2
I mean c'mawwwwwwwwwwwwn. I don't wanna frikken search. C'mawwwwwwwwn C'mawwwn. I don't wanna frikken read. At the risk of dounding srunk...Is it not a simple question? Would it take too much time to post a quickie reply?
Looks like someone came home from the bar at 4:00AM mad that no-one answered him.
How did it get stuck? Are you sure it wasn't the floor mat catching it or something.
If you have replaced your upper intake and did not route the cable properly you could have problems.
Pull it out, spray WD40 down it for 5 minutes. Then dry it off and try to grease it the best you can.
Also check your TB that it didn't stick.
