I need to know which Roller rockers you recomend for my set up. I am using a DSS shortblock. It has forged TRW pistons with valve relifs good for up to 2.08. I will also be using AFR 185 3/8 stud mount heads. I will probably go with the TFS stage 2 cam as of recomendations on this board. Should i use 1.6 or 1.7 RR. Which are some of the good ones? will i be able to use stock lenght push rods too?
Shawn
Discussion Starter · #2 ·
Does anyone know?
What is the lift on that cam? I would stick with 1.6s just because I hear that the geometry is better.
Discussion Starter · #5 ·
yeah i don't think i will run the 1.7 jsut becasue the valves in my heads are so big. I have aftermarket pistons that will clear them but i don't want to push it or anything though. I don't know what cam i am going to be using quiet yet but a lot of people have recomended the TFS Stage 2 cam
Shawn
