I have a stock ignition and the car seems flat above 4800 rpms or so. Should I upgrade my coil and ignition module?
In the latest edition of MM&FF they say the stock coil and ignition module are good for making power up to 4500 rpms.
See my signature for mods. I am going to up the boost to 8psi soon and want to figure this out first.
I know Mallory makes a high performance ignition module for making power up to 9000 rpms and I was thinking about a crane or accel coil.
Thanks for the help
Ray Nist
At 8psi it's not mandatory, but a good idea. The stock ignition is pretty good actually as long as plugs are gapped down for boost. I'd go with the Crane kit for the price or the MSD for the great service after the sale. hth
Thanks for the help
Ray Nist
What system are you going to get for the boost? I only ask because some come with MSD anyway.
Re: Re: Should I upgrade my coil and ignition module??
They come with the MSD retard only....it's not an ignition system in any form. Like the S Trim kit, the MSD box it comes with is simply a timing retard module. hth
Discussion Starter · #5 ·
Acutally, by ignition module, I meant this piece:
http://store.summitracing.com/partdetail.asp?part=22691',650,505,'HLY891105
It attaches to the side of the distributor. I really don't want to spend the money for the complete ignition system right now, I am a little tapped at the moment.
Ray Nist
