Has anyone ever used these lifters or equiviants?
I'm going to be running a cam with very high ramp rates and I'm worried about premature valve float. To cure this I need to run a valve spring with lots of seat pressure. I dont want to be colapsing lifters all the time either.
Here is a link to the lifters incase anyone wants to check them out. (scroll down to the bottom of the page)
http://www.wolfperformance.com/products.html
If you are considering purchasing a set from Ed Hohenberg, email him. He was quick to answer questions I had about the TwEECer which I eventually purchased from him. As you know, he has had alot of success on the strip and has even made a few informative posts here on the Corral. He will tell you whether or not these lifters are right for you.
Oscar
I'm in the same boat. The Sherman lifters are, what, $200? I'm thinking about ponying up another $200 and just get the Crane linked lifters.
I talked to a Crane rep and he said that the Crane linked hydraulic lifters are NOT much lighter than stockers. Anyone ever check the weight of both lifters?
I wonder if the linked lifters will work in my '94 block?
The best person to ask is your engine builder or cam grinder. Steep ramps alone won't necessarily dictate a spring too heavy for the stock lifters, BUT if you couple it with high rpm, then you may need to upgrade.
I would replace 115000 mile stockers if nothing else, even if you find out that the stock type are ok.
