SD to MAF upgrade
566 Views 2 Replies 2 Participants Last post by  indy2000
Ive been looking at a lot of sites regarding MAF sensors etc. and not quite got the answers yet!
I will be doing a conversion from SD at some point while building up the new fox. I have already acquired a couple of MAF meter housings. Engine n stuff is coming from an '88 GT.
One is a 70mm unit and sensor from a 94/95 car (according to the sensor number i looked up) and should work ok (i believe) with 19# injectors without any other changes needed. The ecu i have is A9P.
The second is an 80mm c&l unit with no sensor.
Can anyone tell me if i can use a 93 cobra 70mm MAF unit/sensor with 24# injectors on a A9P (or similar) ecu without any issues?
Also can a 94/95 sensor in a 93 cobra unit (if keeping with 19#) so can be fitted without an adapter.
Hope this makes sense?!
Cheers,
Andy
I guess i could live with the 19# injectors but rather not with the 55mm stock MAF.
But as i already have a 70mm maf/sensor from 94/5GT, 19# and 24# injectors and A9P ecu didnt wanna have to buy too much if i can get as much of this to work together as i can.
But maybe it is best to just buy a MAF unit that is set to work with 24# injectors and stock ecu?
Would i get the best running setup that way?
when you change to a maf with a different transfer function, and change injectors, even of the same size, different injectors of the same flow have different characteristics, you must change the ecm calibration.
