1 - 20 of 30 Posts
I'm trying to figure out the best rpm to launch at with dr's. What rpm seems to work best to work best to launch at with a sc'ed on drag radials?
what mods did you have done with the time in your sig?
all the mods listed got me my time....I know all my time to gain is in my 60' but just trying to figure out how to get it in the 1.8-1.9 range and my elevation is 2200'
Granted, I've only been to the track once, I found that launching at ~ 3,000 rpm worked best for me. I was able to pull off a couple 1.9 60' times. Looks like your elevation is hurting you.
Have you had your car tuned? reason I ask is that I dynoed at 220hp/250tq on a mustang dyno, cut 2.1 and 13.4-13.6 consistantly....I've always felt my HP numbers were really low, guess I may be right.
I'm tuned with hp climbing at 5800 still and a nice flat tq curve......best before sc was a 14.2 @ 100mph
on the dyno I made no more power above 3500rpm&4psi, even 5500rpm&10psi netted a flat 220hp......something screwy here with the dyno.
Are you saying you dyno'd at 220 hp with a blower? Don't you mean 320?
no it came out 220, but this is the thing, I know of someone on this board who dynoed on the same machine, put down 350hp and runs 10's, so what I am saying is there is something screwy with this dyno.
Thats outrageous, even for a Mustang dyno. I would go somewhere else. With your mods you should at least be in the low 300 range on a Mustang dyno.
well, I know it puts down more HP than I can claim, like I said it runs 13.4-13.6 consistantly w/2.1 60' at full weight, oh, and its an auto. No doubt 220 HP wouldn't get it down the track that well.
Discussion Starter #14
I wasn't sure how many lbs of boost I was going to lose through the intercooler so I never installed a smaller pulley plus I wanted to learn how to launch it before I go to a 3.33 pulley
What kind of DR's are you running and at what PSI?
I'm running BFG's - my last time out I went with 16 psi. Best 60' I could manage was 2.09 launching at around 3K. My driving sucks though - not much finesse - just dump it and punch it. :D
Dan
Discussion Starter #16
nitto's 275/40's at 18psi
I was launching at ~2800rpm on 275/40/17 Nitto DR's at 16psi and feathering the clutch... best 60' was a 1.9, mostly consistent 2.0's. Density altitude calculated out to approximately 2500 feet, ugh! I'm going to try 14psi next time out.
1 - 20 of 30 Posts
