Are you saying that I need to tap into the green wire, or detatch the green wire from its grounding location and attach it to the yellow wire from the RPM switch? Im pretty clueless when it comes to wireing the electronics.madmike said:The window switch's yellow wire should be connected directly to the green wire(ground) from the relay.
The relay is then grounded through the MSD once all the switches and rpm are in the right position causing the relay to ground which in turn activates the entire circuit.
No. But if you have a 99+GT, you need a Tach Adapter. MSD makes those as well.on a side note.. do you need to have an MSD ignition box to be able to use the msd window switch?
