1 - 10 of 10 Posts
if u look at my sig, would my combo be better off with a rpm II intake manifold? i was reading some stuff on both of them and RPM says better power above 6000, perfect for supercharger or nitrous, but im not gonna be putting that in my car, and rpm II says good for 1500-6000 or 5500, which sounds better to me. what do u guys think?
I'd stay with the rpm, you aren't flowing enough air with 165's to warrant the swap to a rpm2.
I think the RPM II is a great intake...but definitely not worth switching out my RPM for. If I had to buy a new intake I might invest in it, but I would be extremely surprised if you picked up a noticable gain.
I have a Cobra intake, worth switching?
Discussion Starter · #6 ·
well, do u guys think my intake is a good choice? or which would u guys suggest?
Discussion Starter · #7 ·
from what it sounds and you are running the RPM is fine for you. If you end up going bigger heads/stroke/forced induction, you might want to think about the upgrade.
I'd wait for the RPM version 2.1..... :)
The II may make a bit more power up top; and probably less torque down low (the numbers in the AFM test don't go below 2500; for the street, off-idle to 2500 is one of the most important ranges). If you're looking for signficant improvement, I wouldn't go through the trouble/expense of the swap as your package isn't making power at high enough rpm to really take advantage of the II.
1 - 10 of 10 Posts
