1 - 8 of 8 Posts
I went looking to see if Edelbrock made an EFI 351W RPM Air Gap intake. They make one for the Holden but nothing for a 351W it appears. Does anybody know if the Holden intake will align with aftermarekt 351W head ports?
I'm pretty sure Holden was owned by GM, wouldn't expect it to fit.
Thanks, the Holden intake does not have siamesed runners though, so I thought I would ask.
Hope this link works, looks like a guy had one custom made and was selling it back in 2013
  • Like
Reactions: tmoss
I have read that dual planes are not good for multi-port EFI due to the uneven distribution across the ports. With a carb you just get uneven distribution of the air/fuel mixture, where with port injection it would actually cause different air/fuel ratios among the cylinders. Is this why just about every EFI intake with a 4150 mount is single plane?
Air distribution in most cast intakes vary a bit. Short runners, long runners, runners with bends in them. EFI ensures pretty consistent fuel delivery into the port whereas carb intakes can result in fuel separation/puddling before the port entry. Each has potential issues to deal with, but they both vary in air distribution to a more or lesser degree.
1 - 8 of 8 Posts
