i was thinking of purchasing a set of roush 200 heads
and was wondering if anybody knew anything about them besides whats on there ads
i was told in order to use the windsors piston had to be flycut
is this true on the roush?
also what kind of flow# do these heads produce
any help would be greatly appreciated
thanks :D
Hi Gary,
Sorry I don't have the info .... but if you go to the bottom of the 5.0/5.8 Tech page and put Windsor Heads in the "search this forum" box you'll find some info ... the Windsor Sr and the Roush 200 are similar. The question on fly cutting ... I would guess you would likely have to with stock pistons and the larger valves, but it might depend on what cam you use.
Good luck, Gary
