I am ordering roh snypers, how is the fit with a 17X8 compared to a 17 x 9, i have 275 nitto drags for the back, but i don't know which size rim to get, Clearance is my main concern. Any opinions??
I have ROHs 9.5 in the back with 275 sumitomo HTZs. It does not fit with the quad shock in the stock position. If you flip it you get about a quarter inch maybe 3/8. But you probably could remove those if you haven't already, considering you most likely have a drag setup in the rear. As far as the wheel well goes, i needed to use this special tool made by "snap on" to make the tire fit. Its called a "36 oz ballpeen hammer". Very technical tool only used by professionals ahhahaha. k man good luck
