Is the replacement 94/95 specific. It can always be tig welded, but that might cost more than $65, unless you have a buddy that can do it for a case of beer.Work on the motor and car has been pretty slow. Kind of a pain to work on it since its marooned at my folks house. I spent the last few weekends finishing renovations on my house.
Got some good news and some bad news... Trick Flow finally delivered on a Carb-EO sticker for a street burner intake, bad news is the part number listed is for a silver finish intake, not black, different part number. Additionally, all Trick Flow intakes have no part numbers on them at all. Bottom side of the intake has "TFS-SBF-EFI-2U" cast in the bottom. "2U" is a track heat "1U" is a street burner. one would need to do some deep google work and read forums and look at photos to figure that one out. Both intakes are identical to the naked eye. Shall I slap the Trick Flow back on it and take it to the smog shop with my shiny new sticker? here is a link to the executive order pdf, no part number or product description listed. 1995 mustang gt used for testing
Executive Order D-369-3 Trick Flow Specialties
CARB approval executive order D-369-3 validity, vehicle applications, and document downloadarb.parts
okay bad news time... I think I need a new timing cover. I was cleaning the gasket surface and noticed some huge globs of RTV stuck to the gasket. After cleaning it up some I found 4 pretty large chunks out of the water pump mounting flange.
Would you run this timing cover and just goop it with RTV or buy a replacement for $65 from LMR?
