I know the Factory Rev limiter cuts fuel at 6250 which is bad with my SC'd engine.
Are there any other options besides a new ignition system that will cut the spark instead of fuel?
Ray Nist
MSD 6al and no cut harness to install it cost less than $200
Best for the money
Tim
Yea, a brick under the gas pedal! :D
Sorry, it's Friday.
As suggested the MSD 6al ignition box has different rpm pills you plug in to cut spark at that particular rpm. As suggested the $13 'quick connect' harness is WELL worth the money. Best of luck to ya'
