1 - 15 of 15 Posts
Hi All. Looking for opinions on this estimate I got for the replacement of the engine in my 98 GT....replacing it with a new Factory replacement from Ford, with labor and a couple hundred extra for anything that comes up (new water pump, etc) $4,500.
Is that a fair deal?? Anyone know if Ford will do it cheaper?
Also, to save money is it worth replacing the engine with a used 98 GT engine?? I saw a place on-line (stangparts.com) out of Georgia that sells used engines for $1.700. I need the car back on the road and as inexpensively as possible, but I need as much reliability as possible. This is just a :mad: bad spot to be in.
Anyway, opinions welcome...any advice is worth hearing
Now is the perfect time to upgrade to a 99+ engine. It's not that much more money and it's well worth the power increase you will get. The swap is easy with only a few minor issues to deal with, such as the relocation of the second temp sensor. Anyway, if you decide to stick with a 96-98-headed engine, a Ford dealer is the last place you would want to go. Their reman engines use all stock parts, including the hypereutectic pistons, and are overpriced..........Good luck on whatever you decide...
Discussion Starter · #4 ·
Ok, well thats an option. How do I find a reliable mechanic to do that sort of work?? Seems like just getting an entire motor is less of a hassle and a lower chance of problems down the road
pthornton said:
Buy a used long block. I dropped a 2000 long block with only 2K miles on it in my 96 vert for $675 shipped and $700 labor. I added headers and made 257 RWHP and 300 RWTQ. Check out this site to search for engines. http://car-part.com/
A longblock doesnt come with front accessories or the intake I believe but anyways jsut get a used 99+ motor out of a GT and swap the engines, use the '98 fuel system and '98 coil pack ignition for less hassle. I did this to mine.
Labor was $1000
2000 GT Motor with 18k miles was only $1500
A lot less money than rebuilding your engine or getting a NEW 98 motor plus you get 35 more ponies, and if you want to swap the exhaust manifold for headers now is the time to do it.
Labor = $0.00 if you do it yourself!
Buy a nice longblock out of a wrecked 1999+ GT and put it in your car... just ensure it's in good shape and doesn't have a ton of miles on it.
It will be new ----- for you anyway and you'll have an additional 35hp to start with :)
My 00 GT long block came with all accessories, heads, intake, throttle body fuel rails, and even the clutch. It had 2000 miles and a 90 guarantee. It costs $675 shipped to me. You can search on the site I listed above and just watch for good prices. The $1500 above would be pretty average for a good 99-00 engine with decent miles. http://car-part.com/ Go to this site and do a search for 1999, Ford Mustang, Engine, All States and check out the prices. Prices range from 650 to 3500. Some include transmissions also.
mikesslow50h said:
see sig for what i did. i couldnt be happier.
Thats what Im gonna try to do to mine but I bought a 2001 shortblock and I dont know if the 96-98 4v heads will work on it without any problems.
i dont know if it would work or not, i have absolutly no idea. i got mine compleet from a junkyard type salvage yeard place by my house. it really worked out good because i took all the parts i could from the cobra and put it on my car.
re
Will a 99 or 00 T-45 fit a 96-98 4V motor? I'm also interested in swapping to a 4V for CHEAP! Hoping not to have to buy another tranny
1 - 15 of 15 Posts
