I just replaced the engine harness and the starter relay on my 91 Fox Mustang, and now the car won't start. The gauge cluster lights up when I turn the ignition, and then nothing. I don't hear the click of the starter trying to turn-over or anything. Does this sound like a bad starter or a loose ground?
Side note: I just replaced the factory shifter with a B&M ripper shifter, and the center console is currently not in the car. Don't know if this matters.
Discussion Starter #2
Let me clarify that it is a "no crank" condition. The starter does not crank at all. I installed a new starter solenoid. Could this be the problem?
Did you plug everything in? Is the harness you put in the correct? Have you checked to see if you have a crank signal at the solenoid? Did the car crank before you replaced the harness?
more info needed
stock manual or auto......the start circuits are different
you replaced your stock harness with what?
harnesses are different through 87-93
they are not plug and play.
