Can you get this off with the EGR valve in place?
I dont have a crescent wrench large enough to get the valve off, so I just want to make sure there's no other way. I've got the upper & STB off, but there's still little wiggle room with the coolant tubes and what not...
I think he means that the valve is attached to the tube that goes to the header, and he has already disconnected it from the intake.
Try wiggling it around. In my experience, the lower bolt is rarely tight, and you can often rotate the tube so that it points toward the fenderwell and out of the way.
Discussion Starter · #4 ·
Thanks for the replies- JJxUSAF is correct, and that's what I was hoping for. Thanks!
