1 - 8 of 8 Posts
Here are 2 options where to install the probes:
1. Install the probes on the #2 and #7 header, or
2. Right before the turbo inlet, and another on the downpipe
Which option would you recommend?
Thanks,
Mitch
2 sounds good, but with a little modification. i would place one just beyond the turbine outlet then farther downstream on your exhaust
The most accurate place would be just after the primaries have collected.
There are variables though: distance, design, material etc..
If you place it after the turbo you will lose some heat
If you place it on particular cylinders then if a different cylinder is having a problem you wont know about it.
To use the EGT as a tuning tool it must be as close to the combustion chamber as possible, so if you chose to use 2 probes then I would say choice #1 with the probes 1" from the exhaust port.
Jim
Yep, that's where mine is.
1 - 8 of 8 Posts
