REar End questions
I Am building an 83 mustang with a 502 in it. I plan on running mid 11's, but my big problem is that I have a 7.5 rear end, and thats not gonna work. So my question is do I need to get an 8.8" or a 9" rear end? I am cheap, so I want the cheapest and easiest way to do it. Can I pull them out of cars at junkyards, or do I have to go and buy a new one? Where can I find cheap ones?
A 502 on slicks will likely break any factory 8.8, especially 28 spline axles. That said, you can find a 3.55 28 spline trac lock under 87-88 TurboCoupe Tbirds and a 3.27 28 spline trac lock under LSC Lincoln Mark VIIs. Both are affordable in the junk yard and bolt into a Fox using your existing 7.5" brakes and axles. You might have to upgrade to 31 spline Trac-loc from a Fseries truck and aftermarket axles, but the gears should be OK I would think. Tom
so are you saying that I could use an 8.8 with 31 spline axles?
Get an 8.8 rear and put in 31 splines or bigger axles and spool and bolt it on. Spool is cheaper than posi traction carrier.
Ford 9 inch rear are harder to find now and be prepare to spent big bucks on complete rear assembly.
Discussion Starter · #5 ·
will it be able to handle 11s with 500 plus HP?
